Old 07-08-2011, 09:43 PM   #1
Smile
Changing from a Honeywell T6069A1065 to a Honeywell RTH8500
Hi there,
im having a bit of trouble with this and hope that someone can help me out.
The wires coming out of the wall to the old stat are as follows,
RED
BLUE
BROWN
YELLOW
ORANGE
BLACK
There was a little diagram on the back of the old stat,as follows
The Red,Brown and Blue were hooked up the the fan motor
The Y and O were hooked up the the valves
and the Black was under L1.
The new stat has almost nothing that lines up with these, any help would be great.
Thanks in advance
Macca1004 is offline   Reply With Quote
Old 07-08-2011, 10:10 PM   #2
Hvac Pro
Is it for a heat pump? Post the brand name, model and serial # and someone may recognize it and help. w/o that info no one knows what you have and are trying to do.
Old 07-08-2011, 10:35 PM   #3
Yep its for a heat pump unit in a condo. I will find out the details and brand name and post them. Thanks for the reply
Yet another Honeywell RTH8500 install tayl428 HVAC 2 10-09-2010 10:08 PM
help with installation of Honeywell RTH8500 thermostat dg xy HVAC 19 07-28-2009 01:25 PM
Honeywell RTH8500 spare contacts? golfnut65 HVAC 8 11-21-2008 11:14 AM
help with installation of Honeywell RTH8500 thermostat dg xy Electrical 2 11-13-2008 08:03 PM
Changing from one Honeywell to another... LeroyFrick HVAC 1 11-03-2007 12:33 PM
