Changing The Filter On A Goodman Gas Furance - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 02:06 PM   #1
Changing the filter on a Goodman gas furance
I rent a home that has a Goodman gas furance/AC unit installed. In order to change the filter, I have to unscrew the botttom half of the front of the unit. The wires all hang down and I have to place the 14x25x1 filter inside, under these wires. It always gets stuck and the filter ends up bending. Am I buying the wrong kind of filter? To be honest, I but the cheapest one I can find, usually encased in cardboard. Yes, I shut off the emergency switch first! But I can never get the filter to lay flat where it's supposed to be. Am I doing something wrong? The condensate line for the AC is a real gem too....it's PVC pipe that goes out through the wall. I have to keep a pail under it so it doesn't run down the driveway and pool by the neighbors driveway. Looks like a Rube Goldberg operation to me. The changing of the filter really scares me though.
cavine is offline   Reply With Quote
Old 01-04-2013, 04:11 PM   #2
Rewards Points: 13,274
Got a picture?
Old 01-04-2013, 04:57 PM   #3
I hope I've done this properly:
The first picture is the cover of the Goodman furnace
The 2nd picture is the bottom half open with a the wires and the filter.
Changing filter in Whirlpool whole house water filter farnamct Plumbing 7 12-20-2012 10:11 PM
using a (slightly) larger furance filter sannitig HVAC 2 04-14-2012 12:04 AM
Water Softener started regenerating when I was changing the water filter nicksergeant Plumbing 0 11-07-2010 07:17 PM
Changing the oil filter in boiler eefromjersey HVAC 1 01-19-2009 12:01 PM
Location of Goodman gmp075-4 filter ulaes HVAC 3 12-06-2008 09:33 AM
