Changed Thermostat, Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 06-19-2009, 02:11 PM   #1
Rewards Points: 107
Changed thermostat, not working
I had a new furnace/ac unit installed about three years ago. Always hated the t-stat they supplied with it, was dimly lit and hard to read. Finally had enough of it today and changed it to my old one.
I don't know what brand the one they supplied is, all I can find on it is VT2005. The one I replaced it with is a Honeywell MagicStat/3355. The Vt was a four wire, red, white, yellow, green. I hooked the Honeywell up the same way. Whether it is on heat or air the fan comes on after about ten seconds. The furnace never ignites and the blower keeps running. The air does work, shuts on and off, but the blower keeps running on that also. I do not have it set on constant fan. When the fan was running I switched the switch to system off and it kept running. I then removed all four wires and the fan kept going. I had to go cut the power to the furnace to shut it off. Any ideas? I can not put the VT back on because it got broken during removal. TIA
thunderhead is offline   Reply With Quote
Old 06-19-2009, 02:17 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
It could be one of three things.
1) You didn't buy a compatible thermostat
2) You didn't hook it up correctly
3) Its defective
My guess is the likelihood of which issue it is is in the order I presented above.
Sorry I cant give more specific help.
Brik is offline   Reply With Quote
Old 06-19-2009, 02:34 PM   #3
Rewards Points: 107
The new tstat is actuallythe old tstat that the installers took out when they replaced the furnace. According to the instructions it is compatible with the new furnace. I dont know how I could have hooked it up wrong, but I am no expert either so it may be wrong. There are only fiveterminals on the tstat, R,W,Y,G and one that is marked Rc. The Rc is the one I didn't use. Could that be it? TIA
Old 06-19-2009, 02:45 PM   #4
Handyguy
Brik's Avatar
could be - re-read the installation manual. If you dont have it look here
http://yourhome.honeywell.com/Consum...s/Thermostats/
There may be, or need to be a jumper between R and Rc. Don't put a jumper in unless the manual says it needs to be there. Don't remove one unless the manual says to.
Old 06-19-2009, 02:53 PM   #5
Rewards Points: 107
I just looked again, there is a jumper between r and rc. I looked the tstst up on the site you listed, it is not there. This tstat is about ten years old. On my way to work, will resume when I get home tonight. Thanks for the help.
Old 06-19-2009, 03:47 PM   #6
May want to check for a blown low voltage fuse on the furnace circuit board as a blown fuse will cause a continuous blower on some models. Also you will need to jump r to rc.
SKIP4661 is offline   Reply With Quote
changed thermostat on York Affinity, now no heat? sotwell HVAC 1 03-01-2009 05:34 PM
FAULTY THERMOSTAT!!! What the He.... Krazecon HVAC 11 02-12-2009 04:26 AM
Changed thermostat and have problem ssmcalister HVAC 3 10-29-2008 04:40 PM
Is my thermostat working? pfrich HVAC 2 06-15-2008 09:25 AM
New Thermostat and Furnace Not Working Right Vegas Resident HVAC 1 12-06-2007 06:42 PM
