-   -   Changed thermostat and have problem (http://www.diychatroom.com/f17/changed-thermostat-have-problem-30588/)
ssmcalister 10-24-2008 06:56 PM
A few months ago I upgraded to a programmable thermostat. It worked fine for the summer. I turned the heat on this morning and the heat works but it also makes the ac unit cut on. It didn't do that with my old thermostat. Can someone tell me what I did wrong?
The brand is Hunter, model # is 44155C
The wires are:
G-blue wire
RC-red wire
RH- Red wire
Y/O-no wire
W/B-White wire
Y1-Yellow
beenthere 10-25-2008 11:57 AM
that may be a heat pump thermostat.
Check teh instructions.
See if it is.
Also, look to see if you can set if for furnace with A/C only.
If not. Wrong stat.
ssmcalister 10-25-2008 05:15 PM
Thanks for the reply. Turns out all I had to move was the yellow wire from y1 to y/o. Works great!
simpleman1962 10-29-2008 04:40 PM
If it is a heatpump you should have a wire connected to the O terminal which is the reversing valve/ which reverses from heat to air. usually a brown or orange wire.
Simpleman
