Changed Spark Igniter. Get Pilot But Gas Never Comes On... - HVAC - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 05:26 PM   #1
Changed spark igniter. Get pilot but gas never comes on...
I just changed the spark igniter in my Heil unit as the technician said this was my problem. Model # ntc5100bjc1. now i get a pilot light but the gas never seems to come on
verycold is offline   Reply With Quote
Old 01-20-2011, 06:21 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
check for 24v between p/m and m on the gas valve. Just to clarify you are saying the pilot does light and the main burner does not. If this is so, does the spark ignitor continue to spark after the pilot has lit?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-20-2011, 09:41 PM   #3
the element stays lit the whole time. I don't hear any clicking after i see the light but i'm not positive on that. doesn't go off after the pilot comes on. also the pilot stays on as long as i let it.
can you tell me what this means please
thanks again for the help
Old 01-20-2011, 09:47 PM   #4
AKA HVACTECHFW
well, after what you just wrote, I believe you have a honeywell smart valve gas valve. this is most likely the cause if the pilot does light and the hot surface ignitor does not shut off. Does the part you replaced look like this? IF you have this then you have hot surface ignition and not spark ignition, HUGE difference.
while the system is trying to light, move the connector around for the above picture. This may get the system to ignite
IT IS WHAT IT IS
Old 01-20-2011, 09:55 PM   #5
HVAC / Plumbing
If he has the dumb valve. we know what the problem is
Looked up the mod #. It appears he has the s.v.
kenmac is offline   Reply With Quote
Old 01-21-2011, 01:05 AM   #6
yes that is what i have. i did notice when i changed out the igniter that the wires were not in the same places as the previous one was so i used the old plug and spliced the wires from the new igniter to it. that got the igniter to work nothing after that
Old 01-21-2011, 07:22 AM   #7
AKA HVACTECHFW
sounds like you have a bad splice on the black (flame signal) wire. I have never heard of having to splice these!!!!!!!!!!!! I've replaced a lot of those HSI's and have never had one with a wrong or miswired plug. is the hsi you bought OEM?
IT IS WHAT IT IS
Old 01-21-2011, 08:24 AM   #8
i will check that splice. website i bought it from says OEM but definatly not.
Old 01-21-2011, 08:37 AM   #9
not the splice. checked and rechecked.
Old 01-21-2011, 06:04 PM   #10
AKA HVACTECHFW
ive tired aftermarket ignitors on these before and they dont work very well. Replace with OEM!
IT IS WHAT IT IS
Old 01-21-2011, 06:43 PM   #11
I m curious why you did not just let him do the repair?
hvaclover is offline   Reply With Quote
Old 01-22-2011, 09:37 AM   #12
Used to do the same thing years ago when making 10 cents an hour over minimum wage. Car would break down and couldn't afford for the mechanic to do the repairs but could pay the diagnostic to say exactly what was wrong then fix it myself. Sometimes the repair was going to be more then I had the skill or tools for so paying the mechanic was the only option. Walked to work and back for 6 months, 15 miles a day, back in 82 untill I could save enough for one repair. Life happens and you deal with it.
Old 01-22-2011, 11:20 AM   #13
i just felt like paying 275$ plus an 85$ trip fee was ridiculous when i am perfectly capable of doing this myself. only thing that i should have done is get the OEM part from the start. i have just paid 50$ to realize that
Old 01-22-2011, 11:31 AM   #14
can anybody add a link to the OEM part please. I don't want to purchase another problem. thanks
Old 01-22-2011, 11:57 AM   #15
AKA HVACTECHFW
OEM smart valve ignition assy
IT IS WHAT IT IS
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Old Furnace Igniter Sparks but pilot does not turn on Chak641 HVAC 5 01-11-2011 11:42 AM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 10:11 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 10:37 AM
