Change Steam Radiant Heat To Outside Wood Water Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2007, 07:07 PM   #1
change steam radiant heat to outside wood water heat
Has anyone ever change a steam radiator system to a outside wood furnace and ran water through the registers?
Monteu is offline   Reply With Quote
Old 02-07-2007, 12:40 PM   #2
Is this a one pipe system or two?
redline is offline   Reply With Quote
Old 02-09-2007, 07:04 AM   #3
radiant steam heat
A one pipe system
Old 02-09-2007, 08:22 AM   #4
Do you plan on using a circulation pump to move the water or do you want to keep it steam?
Old 02-10-2007, 02:09 PM   #5
use circulation pump
Old 02-13-2007, 12:19 PM   #6
A one pipe system and a circulation pump will not function. You will need an independent return line.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 04:43 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 02:17 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
