-   -   change steam radiant heat to outside wood water heat (http://www.diychatroom.com/f17/change-steam-radiant-heat-outside-wood-water-heat-6351/)
Monteu 02-06-2007 06:07 PM
Has anyone ever change a steam radiator system to a outside wood furnace and ran water through the registers?
redline 02-07-2007 11:40 AM
Is this a one pipe system or two?
Monteu 02-09-2007 06:04 AM
radiant steam heat
A one pipe system
redline 02-09-2007 07:22 AM
Do you plan on using a circulation pump to move the water or do you want to keep it steam?
Monteu 02-10-2007 01:09 PM
use circulation pump
redline 02-13-2007 11:19 AM
A one pipe system and a circulation pump will not function. You will need an independent return line.
