Change Rotation On Motor? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 09:40 PM   #1
Change rotation on motor?
So i have a Marca Miller-Nordyne p3ra-060k. The fan went out last night so took the motor apart and it was shot, bearings were shot and motor was toast. Went to the local parts warehouse and found a motor that would work for a replacement. Come to find out it is a Counter Clockwise motor and i need a Clockwise. Any way to change the rotation of it. Here are the specs on the motor. Thanks for the help.
Details
Air Conditioner Fan Replacement Motor
1/4 HP
208 - 230 VAC 60 HZ
2 Amps
1 Phase
1075 RPM / 4 Speed
Rotation: CCWLE ; Counter Clockwise Lead End
Frame 48Y
Thermally Protected
Dimensions: Shaft: 1/2" x 3 3/8" Motor: 8 1/4" Total Length x 5 1/2" Dia.
Requires 5 MFD 370 Volt Capacitor (Not Included) A.O. Smith F48G05B65
iamtobejoe is offline   Reply With Quote
Old 08-14-2010, 09:55 PM   #2
Old 08-15-2010, 08:28 AM   #3
Rewards Points: 292
All else being equal, can the fan blade be mounted upside-down?
veesubotee is offline   Reply With Quote
Old 08-15-2010, 04:48 PM   #4
The fan could possibly be mounted reverse.
Old 08-15-2010, 04:59 PM   #5
An old Tradesmen
Rewards Points: 7,816
Not really. It won't be moving the air in the right direction then.
Old 08-15-2010, 05:01 PM   #6
An old Tradesmen
Either get a fan blade that is for that rotation.
Or, get a dual run cap. And wire the motor up as a 3 wire instead of a 4 wire. And wire it to spin the right way.
Old 08-15-2010, 05:40 PM   #7
do you have a diagram on how to wire it the way you are talking about?
Old 08-15-2010, 05:49 PM   #8
An old Tradesmen
No.
Actually wouldn't need to get a dual cap. You can convert your current capacitor set up to 3 wire.
What color wires does your motor have.
black
blue
red
yellow
brown
brown with white stripe
Any others?
Old 08-15-2010, 05:51 PM   #9
the ground being green
Old 08-15-2010, 05:53 PM   #10
An old Tradesmen
Ok. So yellow is the common of the 208/230 volt. Right?
Old 08-15-2010, 05:55 PM   #11
it shows black as common and yellow is the high speed line
Old 08-15-2010, 06:07 PM   #12
An old Tradesmen
Different. But no problem.
First cap off the brown with white stripe wire, its not used.
From L2 of the contactor or control board(which ever it is now). Run a wire to the capacitor(doesn't matter which terminal). Connect the brown wire from the motor to that same terminal. Connect the black wire to the opposite terminal. Connect the speed wires to their speed taps as you have them now.
Turn motor on. Watch which way it spins. If its the wrong way. Switch the brown and black wire on the capacitor(with power off and motor not spinning of course). It will spin the opposite direction then.
Old 08-15-2010, 06:15 PM   #13
well here are the colors as follow
black - high speed
yellow - constant
red - low
blue - med high
orange - med low
brown - cap
brown/white - cap
green - ground
sorry for the confusion
Old 08-15-2010, 06:56 PM   #14
An old Tradesmen
black - high speed
yellow - constant
red - low
blue - med high
orange - med low
brown - cap
brown/white - cap
green - ground
Then just substitute yellow for black in the instructions above.
Old 08-15-2010, 07:47 PM   #15
was trying the formula you gave me and was turning over the motor at all. Plugged the black into t1 and brown/white and brown into the cap on opposite sides with a wire from t2 two one side of the cap. had the yellow at t2 also. turned the breaker on and fan kick the right way and was on high. went to tuck everything in and put it back together and the yellow was broken and laying in. though "crap". turned the breaker back on and the fan kicked again with no yellow connected. do not understand how its running but left it alone. thanks for all the help if i had not tried what you said i would have fallen upon this configuration.
New fan motor going out? DavidI HVAC 5 06-23-2010 10:38 AM
Air Handler Motor Wiring brando1118 HVAC 13 06-18-2010 11:42 AM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 05:13 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 06:30 PM
Zone Valve change motor jim99 HVAC 2 07-22-2007 06:37 AM
