Change Out... Going 7 Days On That Stat - HVAC - DIY Chatroom Home Improvement Forum
Old 04-05-2013, 11:27 AM   #1
biggles's Avatar
change out... going 7 days on that stat
was just in HD and they have a Honeywell digital stat for under $50 that can handle ac/heat and does a 7 day programming with a green led display.easy 5 wire change out ..might need the C side of the furnace TR but it is mint for a DIYer...just do the world a favor.. ..and shut the furnace toggle 115v off or the breaker for that furnace during the flip.while you at it get an in-line auto fuse holder with a 3A-5A fuse for the yellow wire off that TR... if there isn't a control board in that furnace...or if the board doesn't have one Honeywell package number is RTH6350D....
Old 04-06-2013, 12:23 PM   #2
Rewards Points: 610
why the furious face...preeze exprain mo!!...do you mean you require extra transformer and if so, what for? ..cooling only?...understand to turn off power..doesn't everyone? Just bought similar stat but haven't installed yet..HW RCT8100A..for oil fired FWA furnace..no cooling but may add this spring..ny issues to look for? THANKS
techpappy is offline   Reply With Quote
Old 04-06-2013, 05:37 PM   #3
biggles's Avatar
some don't on that power.and wing it.. and pop goes a non fused tr....$$$ that C comment depends on your old stat might of worked on a feed back and not to much solid stat ..old style Honeywells with the tan led screen .the newer stats with the big displays call for a constant 24Vs at the R to C read with a meter on the subbase...so you have 2 wires to the old sta might need a 3rd to catch that C side of the TR
The Following User Says Thank You to biggles For This Useful Post:
techpappy (04-06-2013)
Old 04-06-2013, 05:53 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
I get digital 7 day Honeywell programmable stats from HD for $30. Non programmable for $20.00. I'm not sure your complaint, but whatever works, works.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 04-06-2013, 06:28 PM   #5
Rewards Points: 610
Biggles..your comments made me think of a time back in 1970 when I went to fire up a new 250 HP Cleaver Brooks boiler at Warner Lambert in Toronto. Checked it all over then told the sparky it was OK to turn on the breaker. Next thing I knew, smoke started to billow out from the boiler control panel. They had installed 24V, plug in relays instead of 120V. They obviously hadn't test fired that boiler before it left the plant. A little bit of excitement but no biggy though. Just went back to the shop and got new relays.
Old 04-06-2013, 07:18 PM   #6
DoOd, I was born in '76.
Thanks.
Old 04-06-2013, 07:51 PM   #7
Rewards Points: 610
1946 retired and enjoying it...old enough to be your pappy but, I still miss the good ol' days when I was on the road and flying all over.. troubleshooting
Nuthin' feels better than solving a cantankerous problem...well, almost nuthin'
Old 04-06-2013, 07:58 PM   #8
what the heck is cantankerous?
Thanks.
Old 04-06-2013, 08:42 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
cantankerous
▶ adjective bad-tempered, argumentative, and uncooperative:
sublime2 is offline   Reply With Quote
ATF Never changed in 135K Miles - Leave or Change it? amodoko Automotive Repairs 46 04-26-2013 06:00 AM
Change your clocks, AND Your Smoke Alarm Batteries!! Firefighter3244 General DIY Discussions 10 03-10-2013 06:19 PM
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 05:53 AM
Changing potty. Do I need to change the flange out? tarheelblue Plumbing 9 09-04-2008 11:41 PM
ritetemp programmable stat miked18 HVAC 9 12-17-2007 06:20 PM
