Old 11-05-2009, 01:31 AM   #1
KatzDad
katzdad's Avatar
Default Change circuit breaker amps for downgrade?
Hi all,
I'm replacing my old 15 KW electric furnace in my mobile home with a new 12 KW model. In checking out the wiring instructions, I note that the 15 KW needs a 90 amp circuit breaker, while the 12 KW only needs 70 amps. Also, the wiring requirements are different. I currently have a 90 amp one installed, along with the larger size wiring (2 pole). Is there any problem using my current circuit breaker and/or wiring?
Thanks,
Max
katzdad is offline   Reply With Quote
Old 11-05-2009, 01:35 AM   #2
Houston204's Avatar
It would be safer to replace your breaker. The heavier wire that you already have should be fine.
Houston204 is offline   Reply With Quote
Old 11-05-2009, 06:37 AM   #3
An old Tradesmen
Yep. Change breaker. Wire is fine.
More On This Topic
Hi! This is John from expertvillage.com. In this video clip, I will be discussing the electrical requirements for chop saws. This particular saw is wired at the factory for a standard 120 volt connection. You want to connect it to a 120 volt, 15 amp time... Read More »
Basic Hot Tub Wiring
Basic Hot Tub Wiring by Expert Village
OK, here we're going to talk about the different wiring requirements for spas. Many spas, most common will be a two-forty volt, fifty amp dedicated circuit, which means that is it on its own breaker, it is a GFCI breaker which is for your safety and also... Read More »
Hi! My name is Chad Smith and I'm a state certified Journeyman Wireman basically a electrician and I'm representing expertvillage.com. Today we are installing a new doorbell in our house here. The first step that you should take when you are installing... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Let's talk about putting a sign on the breaker box to warn others to avoid others turning our breaker back on. You can say something on your sign similar to what I have. Do not turn circuit breaker number 15 on. Bill is installing a dimmer switch in the... Read More »
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 11:41 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 10:38 AM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 04:44 PM
Transformer Help chcustom Electrical 28 12-11-2007 12:40 AM
New homeowner here...circuit breaker question fenway71 Electrical 7 01-18-2006 10:39 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
