Centrifugal Switch Is Stuck Open - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 10:32 AM   #1
mon
centrifugal switch is stuck open
where is the centrifugal switch for a coleman evcon furnace
model# dgat070bdd
serial#970138098
Ive checked all fans and Ive changed the limit switch
mon is offline   Reply With Quote
Old 02-22-2011, 11:09 AM   #2
That motor has no centrifugal switch.
It's a direct drive.
Check to see if you are getting power to the motor when its running.
hvaclover is offline   Reply With Quote
Old 02-22-2011, 11:18 AM   #3
mon
it shows on the panel that the light that flashes 3times means the centrifugal switch is open and there is a diagram that shows there is one on the furnace however I am not able to locate the switch.....
Old 02-22-2011, 11:40 AM   #4
Parts blow up shows no switch.
Could be in the booster motor....you sure it does say pressure switch?
I
Old 02-22-2011, 11:46 AM   #5
Previous
Return to the Product List
Next
larger image
larger image
Coleman Booster Motor/Centrifugal Switch 7990-317P/A
$88.00
Combination booster motor and centrifugal switch. Centrifugal switch cannot be sold separately. Replaces 7990-317 & 7990-317P.
The Following User Says Thank You to hvaclover For This Useful Post:
mon (02-22-2011)
Old 02-22-2011, 12:37 PM   #6
mon
Thank you for your help , that was very useful......
Old 02-22-2011, 12:50 PM   #7
No prob..
Wait 'til you get my bill
Old 10-18-2011, 10:49 AM   #8
centrifugal switch
where do i locate this switch on the colmen model DGAT090BDE....AND HOW DO I REPLACE IT? do i have to replace the blower too?
gang5ta boogie is offline   Reply With Quote
Old 10-18-2011, 11:22 AM   #9
Experienced
Jackofall1's Avatar
http://www.mobilehomedepotmi.com/par...dgat_dlas.html
Old 10-18-2011, 12:01 PM   #10
centrifugal switch
still dont know where my switch is? it does not show the (centrifugal switch) is there another name for it? and is it some thing i can order and install myself?
thanks for help
Old 10-18-2011, 12:03 PM   #11
Experienced
Jackofall1's Avatar
Booster motor and switch are an assembly and can't be purchased seperately, the diagram I had attached shows the breakdown of the assmebly and were it is located on the furnace.
Mark
Old 10-18-2011, 12:19 PM   #12
centrifugal switch
im sorry but i dont see it...is it the 6-10 (booster motor/assembly)
Old 10-18-2011, 12:25 PM   #13
Experienced
Jackofall1's Avatar
yes exactly
Old 10-18-2011, 12:29 PM   #14
centrifugal switch
thanks allot u made it easier for to find it...now one in my area sells them to non-licensed ppl so where can i buy one at?
Old 10-18-2011, 12:39 PM   #15
Experienced
Jackofall1's Avatar
It is list here
http://www.searspartsdirect.com/part...6&prst=&shdMod=
Mark
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
Switch now controls large area... froddan Electrical 5 12-06-2009 10:04 PM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 07:05 PM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 11:33 AM
