Centre Air Conditional System Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 06-08-2010, 06:50 PM   #1
Rewards Points: 29
Question
Centre Air conditional system problem
Hi there, We are a fasion store in a shopping mall, our unit's thermostat looks working fine, when you turn it on, it display cooling model, we also can heared the fan working, but no cold air comes out, the fan looks working, and our neighbor's units everything fine, just our unit no cooling, what wrong with it!? due to this is a centre air conditional system, the problem should be in our unit only, but everything looks fine, anybody can give some ideas? thanks
Ballastar is offline   Reply With Quote
Old 06-08-2010, 07:13 PM   #2
Could be a long list of things. Have the tools needed to check it out? If so locate the AC, usually on the roof of a mall around here, and tell us if it's getting high and low voltage. We'll start there instead of going through every possible cause of no cool.
Old 06-08-2010, 09:44 PM   #3
Rewards Points: 29
Somebody said the compressor may broken, (I did not find it yet), if yes, how can I check it works or not? or is there has a relay does not working?
Hot Water Heating Problem....please help gor4200 HVAC 6 01-24-2011 02:17 AM
beware humidity system? Emaderton3 HVAC 5 02-11-2010 12:52 AM
Trane XL1200 Heat Pump Condenser Fan Problem peglegpirate HVAC 3 10-20-2009 10:43 PM
Honeywell RTH7000 and Goodman System Problem jvd1812 HVAC 1 11-08-2008 12:51 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
