Central Home Oil Heater, Pump Cavitating, What To Do? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 11:05 PM   #1
Rewards Points: 109
central home oil heater, pump cavitating, what to do?
I had to move the tank 3 feet further down towards ground. So, now the heater pump needs to pull fuel up 3 more feet. There was already a long distance from tank to pump. About 40 feet. The tank was at the same height as the pump. fuel got pulled up about 5 feet, over about 30, then down about 5 feet. Its been working like this for 26 years. However, I had to move tank down 3 feet. So, its now pulling up 8 feet, then over 30 feet, then down 5 feet. However, now it keeps cavitating. What to do? Last resort is to move the tank back up. Someone said a small low pressure automotive fuel pump mounted at the tank to push the fuel. This work?
tks,
pa
paulmars is offline   Reply With Quote
need to descale my tankless heater can you use a sump pump loki993 Plumbing 4 10-23-2012 08:46 AM
Heat Pump Water Heater Review wassermeister Plumbing 0 08-25-2012 03:35 PM
Electric Wiring for Pool Heater (heat pump) tazmajazz Electrical 7 10-21-2009 08:49 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
gas water heater connected to central air/heater? slowlearner Plumbing 2 02-22-2009 10:49 AM
