Central Heating System With No Spot For Filter? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 12:01 PM   #1
Rewards Points: 85
Central heating system with no spot for filter?
My friend lives in a house with central heat/AC. I could be wrong, but where the return duct comes back into the main unit, shouldn't there be a spot for a filter? In this case, there is not a spot; it is just taped shut.
Could this be normal, or no? I've never seen a central air/heat unit without a main filter, and I can't imagine all the dust/dirt/debris/etc. that the blower motor and other components are collecting. Could the filter(s) be located at each return vent in the house (those vents are only 6"x9")? If so, I'd assume that there should still be a filter at the main unit.
Chris Sweeney is offline   Reply With Quote
Old 10-07-2012, 01:18 PM   #2
Rewards Points: 616
you are correct ...there should be a filter...
carmon is offline   Reply With Quote
Old 10-07-2012, 01:59 PM   #3
biggles's Avatar
trace back from the unit all the returns have to hit the main return someplace...filter might be there.if not remove the supply fan access panel and where the return comes into the unit slide one in there for now...no big return grill somewhere around the stat area as usual
Old 10-07-2012, 02:52 PM   #4
Rewards Points: 85
Just checked in the basement...no signs of filters anywhere along the return ducts. Any other suggestions anyone?
Old 10-07-2012, 02:57 PM   #5
Rewards Points: 258
is there a plate on the return duct that could be removed, plate would be the same lenght as the duct and about 2-3 inches wide, held in by 4 screws
redman88 is offline   Reply With Quote
Old 10-07-2012, 03:12 PM   #6
Rewards Points: 85
Hmmm, where on the return duct? Right near where it enters into the main unit?
Old 10-07-2012, 03:17 PM   #7
Rewards Points: 6,652
It should be right at the unit, or can be inside once you remove the blower access door.
Old 10-07-2012, 04:52 PM   #8
Rewards Points: 85
Here are a couple pics. This first pic shows the return on the right coming in to the furnace on the left. It's foil-taped shut (no spot for a filter):
In this second picture, I removed the access panel on the back of the furnace unit. Still, nothing where the return duct (left) comes into the furnace (right):
Old 10-07-2012, 07:30 PM   #9
If there is not a spot at the furnace, or inside the furnace at the blower area, probably was one placed into the returns, if they are large enough to hold one either flat inside, or at a angle inside the opening.
Old 10-07-2012, 09:22 PM   #10
Rewards Points: 610
That second pic looks like the ID Fan ...Open panel/door to access circulating fan /motor..could be filter rack in there.
techpappy is offline   Reply With Quote
Old 10-07-2012, 09:29 PM   #11
Rewards Points: 258
that would place the filter way close to the burners
Old 10-07-2012, 09:53 PM   #12
Rewards Points: 610
It does look like there should be a filter channel in the return duct near thr furnace, however, as is the case with my furnace, there may be an access door to the circulating fan where there is a filter rack on top..they do exist in some furnaces including mine.
Old 10-07-2012, 11:46 PM   #13
You may have somethin SIMILAR to this in the blower cabinet itself.. Look and see, if not a filter rack needs to be installed
Nickhvactech is offline   Reply With Quote
Old 10-07-2012, 11:55 PM   #14
nickhvactech, did you not read the whole thread.
Old 10-08-2012, 12:01 AM   #15
Nope.. now that i have, i get your point !
NEWBIE
Hydronic Air PEX Piping Deteriorating - Repipe or Install New Heating System? aoreo HVAC 9 06-25-2010 08:36 PM
What should I do? Replacing heating system mynd66 HVAC 22 11-17-2009 05:30 AM
Installing a New Central Air System vdu HVAC 7 09-01-2009 04:45 PM
Wanna help design a hydronic radiant heating system? YerDugliness Green Home Improvement 4 05-03-2009 11:10 AM
Choosing a New Heating System...help Hydronic Heating Peter Kingsbury HVAC 1 10-21-2008 11:04 PM
