Central Heating Pump Noisy And No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 03-30-2005, 12:47 PM   #1
Central heating pump noisy and no heat
Any help please.
Central heating/hot water pump seems noisy and the radiators and hot water tank are not getting hot. Boiler fires up fine. Any suggestions.
Thanks.
goldenlay is offline   Reply With Quote
Old 04-02-2005, 06:30 AM   #2
First guess is you have air in the system. The pump also could be worn or malfunctioning. Even newer pumps are noisier when they are air locked though. Look for any air bleeds on higher parts of your system and try bleeding air out. Do you only have one pump for your heat and hot water tank?
Mgmopar
MgMopar is offline   Reply With Quote
