Central Heater Does Not Work In Auto - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 10:34 AM   #1
Central Heater does not work in Auto
Hi, I live in Florida and have a forced air central AC unit with 15kw heat. The AC works ok but the heater and air handler won't come on. All I hear is a relay or something that clicks like the heat is beginning come on. The air handler does not come on and I can see that electrical load is becoming lighter after a few seconds followed by another click. If I select the fan to run and I slide the heat on, it comes on running very well.
Incidentally, while running the heat in manual mode, I put the Auto/fan switch into auto and the fan speed dropped to half. I'm not sure if the airhandler is two speed or not. I seem to have both both phases working.
sweedzel is offline   Reply With Quote
Old 01-25-2013, 08:05 PM   #2
An old Tradesmen
Rewards Points: 6,500
Could be a bad sequencer.
Old 01-27-2013, 11:07 PM   #3
Hey, thanks that sounds logical.
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Convert portable AC to mini central AC. Any reason why this would not work? Red Squirrel HVAC 18 03-31-2011 09:13 PM
Hunter Thermostat Model 44860 Heat Pump Emergency Heat Does Not Work On Auto stvnhdmpa HVAC 8 12-08-2010 06:44 PM
Low speed blower won't work in auto mode Eric F HVAC 16 10-29-2008 06:24 PM
Central vac, freezer, and gas water heater on same circuit? curls00 Electrical 7 03-10-2008 10:57 PM
