Central Heat Will Not Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 11-21-2006, 09:35 AM   #1
Central heat will not shut off
I have gas heat (central) and the blower moter does not shut off. The heater it s self will light when it gets cold and goes off etc but the fan runs all the time.
I am thinking it may be thermostat but do not want to start replacing it unless have other oppinions with more experience.
femartist is offline   Reply With Quote
Old 11-21-2006, 09:41 PM   #2
heater problems
sometime gas furnaces have a switch on the side of the furnace called the summer fan, if this switch is on the blower will run all the time, just turn it off and the furnace should run fine, if there is no switch on the side of the furnace then it probably in the t-stat
kidd is offline   Reply With Quote
