Central Heat Blowing Cold Please Help - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 12:34 AM   #1
Last winter my mother had her combi boiler replaced with a GE PG series hot water heater and Burnham Series 2 gas boiler. After the install, the central heat worked well but the baseboard heaters downstairs were off a few degrees, i.e. if the thermostat was set to 70 it would only reach 65. The central air conditioning worked over the summer.
This year I have the central heat set for 72 but the air coming from the vents is not warm at all and the house is not getting heated(temp stays at 66 even after hours of running the heat on auto). However, the baseboard heaters downstairs are on and around 75 degrees even if I set the thermostat to 50.
Hot water works and the boiler is definitely lit. Any ideas on what's going on? Thanks for looking.
blueprint99 is offline   Reply With Quote
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 08:48 PM
Heat Pump Not Blowing Cold RB101011 HVAC 18 09-29-2011 11:03 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
HEIL/ICP gas/electric self-contained unit -- blowing cold air, won't shut off AboveTheBULL HVAC 3 06-28-2010 07:23 AM
Central Air Turns to Cold Air Heresteve2 HVAC 3 01-07-2010 09:26 PM
