Central A/C Turns Off Every Night At Midnight? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-26-2009, 07:15 AM   #1
Central A/C turns off every night at midnight?
Hi,
My central A/C has a problem where every night around midnight it seems to turn off and not respond to the thermostats call to turn on. I end up waking up every night around 12:30 very hot, walk to the thermostat (which is set to 73 deg. and AUTO), see that it is calling for cooling but that nothing is happening. I move the switch from AUTO to FAN and I start to get some air blowing into the room which is enough to help with the temperature and I fall back asleep.
Any idea what is going on? I've checked the programming of the thermostat and it seems fine. The A/C system works perfectly over the course of the day. I only have this one issue every single night around midnight.
RKDuke is offline   Reply With Quote
Old 08-26-2009, 07:25 AM   #2
Is the A/C on your power company's shutoff program?
jerryh3 is offline   Reply With Quote
Old 08-26-2009, 09:09 AM   #3
Good question Jerryh3 - I just moved into this home. How would I find that out? Would a power company's shutoff program only affect the condenser and not the blower?
Old 08-26-2009, 09:47 AM   #4
Look between your breaker panel and the outside condenser. There would be a box that the power wire runs into and out of.
Old 08-26-2009, 12:48 PM   #5
ok, I'll look for that tonight when I get home jerryh3. If it is indeed there how do I prevent my A/C from turning off in the middle of the night?
Old 08-26-2009, 12:52 PM   #6
A progammable thermostat....
Had one at a vacation rental that was hard to figure out the settings
Of course since it was a rental they wanted to control to a degree the settings
Old 08-26-2009, 03:06 PM   #7
try this
If you find out you are not tied to the electric company take the thermostat off programming and just run the unit on manual a day or two at your desired temperature and see what happens.
SULTINI is offline   Reply With Quote
Old 08-26-2009, 03:32 PM   #8
good idea Sultini. I'll try that.
Old 08-26-2009, 03:33 PM   #9
How old is the thermostat?
Far stretch....but
I know there were Y2k problems with some - & they failed at midnight
There are also all sorts of "trip dates" (failure) since Y2K
But I couldn't find one for 2008, for 2009 next one is 09/09/09
Old 08-27-2009, 06:00 PM   #10
biggles's Avatar
if you set all the temperatures the same.....the modes are aced out no matter what the times are set for that 24 hour run
Old 08-28-2009, 07:28 AM   #11
Investigation is still in process. I did set the thermostat to "manual" last night at a constant temperature. That succeeded in keeping the room cool. Next step is to figure out why it doesn't function properly in "Auto" mode. May just be a defective thermostat that needs to be replaced.
Old 08-28-2009, 09:19 AM   #12
So far
So far so good keep it on for another day or two and go from there.
If it works then may be a new stat is in order.
Worth it for Central Air John84 HVAC 13 07-21-2009 07:00 PM
Help please, Central Air not working properly ned4spd8874 HVAC 8 06-21-2009 12:32 PM
adding central air poger67 HVAC 3 04-28-2009 10:58 AM
Central vac, freezer, and gas water heater on same circuit? curls00 Electrical 7 03-10-2008 10:57 PM
