Central A/C Stops Working Same Time Every Day - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 10:33 PM   #1
Central A/C stops working same time every day
This has happened for three days now. Our central A/C just stops working around 1:30 pm. The fan won't blow and we can't force it on. Then, around 8:40 pm, it kicks back on again, working all night long until around 1:30 the next day.
A/C guy came out this morning and said that our programmable thermostat (which was only 4 months old) was probaly faulty. He replaced it with another one and programmed it himself.
Well, come 1:30ish today, the A/C turned itself off again. Then it turned back on at 8:35 pm.
I called the A/C guy and he is coming out to look at it again tomorrow. But, he said he really doesn't know what could be the problem.
Why in the world would our unit turn off & on like that at nearly THE SAME TIME every day?
mckwvu is offline   Reply With Quote
Old 06-15-2009, 10:56 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I'd have him show up about 1:15pm
Old 06-15-2009, 11:01 PM   #3
Is this the inside unit, outside unit or both?
Do you have an energy management box installed by the power company?
SKIP4661 is offline   Reply With Quote
Old 06-15-2009, 11:03 PM   #4
It's both inside & outside. I asked the guy to show up about the time that it quits on me but he said he can only come in the morning. Not sure why you would show up when it is working...
Old 06-16-2009, 08:39 AM   #5
Joe F's Avatar
Rewards Points: 294
Exactly what I was thinking.
If you want to test and see if the t-stat is the problem, change the time of day in the t-stat. See if the problem corresponds to the time the t-stat :"thinks" it is or the real time. You might want to try a different A/C guy too.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 06-16-2009, 08:51 AM   #6
No energy management box. I am going to try to switch the times on the thermostat this morning and see if that works. If the guy can't figure it out today, then I may find someone else to check it out. Problem is, we were assigned to him through our home warranty...
Old 06-16-2009, 09:20 AM   #7
Boy, are you screwed.
Warranty companies will take the least line of resistance on a repair.
hvaclover is offline   Reply With Quote
Old 06-16-2009, 09:33 AM   #8
That's not what I wanted to hear!
At this point we are thinking the A/C may just be on its last leg. It's about 15 years old. I have little faith that the warranty company will replace it...
Old 06-16-2009, 10:42 AM   #9
What you describe is " The Ghost In The Machine" scenario.
I will say that a programmable stat can cause your problem.
Or the guy programmed it wrong.
When the second guys comes back read the programing instruction just to make sure you are not defaulting back to factory setting.
If it does it a third time your problem is some where else. Question: Do you have a second electric meter that reads the ac current draw only?
Old 06-16-2009, 11:11 AM   #10
Home Air Direct's Avatar
Almost has to be the stat. If all else fails, have them put a simple heat/cool non-programmable or mechanical stat on.
If that doesn't work, move, because there is something else living in your house besides you that gets chilly during the afternoon.
btw....sorry to hear you have a home warranty. With HVAC, those are rarely a good idea. Just think about that at renewal time.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 06-16-2009, 11:01 PM   #11
on/off
it sounds as though it's twelve hours off. it thinks it's am and it should be pm.
joesbarngrill60 is offline   Reply With Quote
Old 06-16-2009, 11:11 PM   #12
Tired & Dirty
Rewards Points: 83
should be a way to switch it to manual for a test
evapman is offline   Reply With Quote
Inside Fan not working BenH HVAC 20 07-08-2008 07:10 AM
Working with granite... SDeeter19464 Remodeling 5 06-14-2008 06:51 AM
Central Air shuga HVAC 4 06-10-2008 07:58 PM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
