Central A/C Not Working After Power Outage - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 06:03 AM   #16
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by rs1971 View Post
It was worth a try but no dice. If nothing else, at least I'm getting good at resetting all of the digital clocks in the house.
-rs1971
Dang, forgot I said that already. Reset them again.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-22-2012, 06:39 AM   #17
biggles's Avatar
if the transformer is shot it won't be warm to the touchif it is with all the breakers on inside the 24V side might be opendo you see or hear clicking when you work the servcie switch on the side of the air handler..even clicking will indicate 24Vs...LED screen on the stat if you have one.if you had a 12V tester or bulb handy you can check those fuses with the car batteries +/-..... for continuity if your up in the mountains there.at the condenser if your fuses are in place in the knife holder you push in giving the compressor contactor a qhick push with the end of a pencil will indicate power....just a quick BUMP ON...
Solar at the cottage? Tito1800 Home Theater 2 01-18-2012 02:30 PM
power outage BAILEYANNE General DIY Discussions 12 11-28-2011 09:50 PM
central vac stopped working wendl Appliances 2 07-04-2010 08:06 PM
Help please, Central Air not working properly ned4spd8874 HVAC 8 06-21-2009 11:32 AM
Central A/C stops working same time every day mckwvu HVAC 11 06-16-2009 10:11 PM
