Central A/c Line Set Sizing - HVAC - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 11:37 AM   #1
central a/c line set sizing
What is the proper line set sizing for a 4 ton condenser. asbout 40 feet from the acoil/blower
skifreak506 is offline   Reply With Quote
Old 05-18-2011, 11:53 AM   #2
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Is the condenser above or below the a coil?
what size are the fittings coming from the unit?
Big N8 is offline   Reply With Quote
Old 05-18-2011, 04:44 PM   #3
An old Tradesmen
Rewards Points: 8,184
The install manual will have that info in it.
If you don't have the install manual. Post brand and model number of your condenser.
Some brands use a different size then other brands for the same efficiency.
Old 05-18-2011, 05:02 PM   #4
Check your manual, but I'll bet it calls for a 3/8" and 7/8".
brandonmcginnis is offline   Reply With Quote
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 07:53 AM
Help sizing a gas line stubborn1 Plumbing 3 11-30-2008 11:38 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
