Central A/C And Heat Stopped Working, But Fan Still Blows - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 11:03 AM   #1
Central A/C and Heat stopped working, but fan still blows
About a week ago, our AC stopped blowing cold air on the hottest day ever recorded in L.A. It's a central unit. The weird thing is that it no longer blows hot air from the heater either. The blower/fan still works, but just no hot or cold air. I don't know anything about AC/Heat systems, and before I hire someone to come in to my home, I would like to know a little more about what this could possibly be..maybe even something very simple. Does anyone have an idea as to what could be causing this problem? Any advice would be very appreciated!!
Thanks!
blahblah is offline   Reply With Quote
Old 10-05-2010, 03:03 PM   #2
Seasoned DIYer
Rewards Points: 150
Thanks!
If it's a heat pump, loss of refrigerant will cause loss of both functions.
HVAC_NW is offline   Reply With Quote
Old 10-05-2010, 03:37 PM   #3
Rewards Points: 161
Have you checked the circuit breakers?
kb3ca is offline   Reply With Quote
Old 10-05-2010, 05:58 PM   #4
Yes I did check the circuit breaker. I even shut it on and off hoping that would somehow help.
Old 10-05-2010, 06:17 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,842
Post the make and model #.
Old 10-05-2010, 06:31 PM   #6
Seasoned DIYer
Rewards Points: 150
Does it use gas for fuel for heat at all?
Does the outside machine normally run when you're using heat?
Old 10-05-2010, 06:33 PM   #7
Sure, it's made by Trane and model #TWVO36A14O8O
Old 10-05-2010, 06:36 PM   #8
I believe it uses gas for heat. And I'm not sure what you mean by the second question, but the central air unit is inside the house. I'm sorry, I just really don't know anything about this stuff.
Old 10-05-2010, 06:41 PM   #9
Seasoned DIYer
Rewards Points: 150
I feel its beyond your hands. I don't have much else to suggest, other than call for service.
Furnace is working but no heat Lon1974 HVAC 21 09-12-2010 10:00 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 06:04 PM
heat pump not working kyleGR HVAC 2 05-30-2006 02:35 PM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 05:47 PM
