Central Air Unit Removel - HVAC - DIY Chatroom Home Improvement Forum
Old 02-25-2009, 09:30 AM   #1
Question
central air unit removel
I am rmoving a new unit i had installed and i want 2 know do i have depressurize the compressor.
big mikec is offline   Reply With Quote
Old 02-25-2009, 09:56 AM   #2
An old Tradesmen
Rewards Points: 6,592
Either needs to be recovered, or pumped back to the condenser.
Old 02-25-2009, 10:21 AM   #3
Home Air Direct's Avatar
I am sure someone will tell you that you can pull the vacuum with the unit its self, but if you are a quality diy, you will recognize that this is not the arena you need to be in.
I think you can set the unit, run the lineset, run the elec (maybe), run the control wires. But I also think there is an absolute need for assistance beyond that.
Call a pro for the vac or reclaim, and restart. Making an error here is against the law. Don't risk it. I love DIY, but I think all of us need to draw the line at times and I think this is one of those time.
Be safe and smart.
Good Luck
Jay
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 02-25-2009, 11:27 AM   #4
Agreed! Do the things that give you the best reward over risk. There are too many things that can be done wrong when drawing down, disconnecting, re-brazing, recharging and restarting a system when you consider the minimal cost in paying a pro to take the risk.
dac122 is offline   Reply With Quote
Old 02-25-2009, 01:22 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
"Best reward over risk", I like that. I would rather work a few hours overtime at what I do best and pay a Pro to shingle a steep roof or a painter to do a neat job vs the mess I would make.
Old 02-25-2009, 03:03 PM   #6
Not to mention the fact that unless you have an EPA card you will get Jail time in a federal slammer as well as a $25,000 fine.
hvaclover is offline   Reply With Quote
Old 02-25-2009, 03:22 PM   #7
Rewards Points: 1,910
What HVAClover said. Big time legal problems if you don't have the EPA license or if you release the freon to atmosphere.
Old 02-25-2009, 09:44 PM   #8
dont move it yourself there are to many easily breakable part and u have to recover the refrigerant and if it is an R-22 system then u will not be able to get any anymore the E.P.A. stop making it due to ozone depletion and plus if u do not have a universial E.P.A. license then u will not be able to purchase and 30 lbs. bottle of refrigerant (most systems require at least 32 lbs.). My professional advice is dont move the unit let a qualifed tech do it.
drafter is offline   Reply With Quote
Old 02-25-2009, 09:56 PM   #9
HVAC / Plumbing
Only if caught
kenmac is offline   Reply With Quote
Old 02-25-2009, 10:01 PM   #10
HVAC / Plumbing
I doubt he could move it without a crane if it takes that much refrigerant
Old 02-26-2009, 06:21 AM   #11
An old Tradesmen
The EPA has never made refrigerant.
The only resi systems I've seen that had 32 pounds of refrigerant in them.
Were over charged by some hack.
R22 is still made today, and will be for years to come.
If you think its best for the OP to use a contractor. Just say so.
Don't make crap up.
Old 02-26-2009, 08:40 AM   #12
Don't make crap up.
Been, did you notice not one period was used? I don't know, maybe it's just me who can't make sense out of gibberish,
Old 02-26-2009, 01:15 PM   #13
An old Tradesmen
I have plenty of periods in my post.
Old 02-26-2009, 02:03 PM   #14
Not you, silly! I mean Drafter.
I quoted your post thinking his post would show too.
Sorry.
Old 02-26-2009, 04:29 PM   #15
HVAC / Plumbing
I'm old enough , I don't have them anymore
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 11:23 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 06:10 PM
Used Central Air Unit? shep28 HVAC 2 04-21-2007 08:59 PM
central air unit question princessme HVAC 4 07-08-2006 10:13 PM
