Central Air Unit Is Freezing Up, All Fans Working - HVAC - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 09:01 PM   #1
Central Air Unit is freezing up, all fans working
Cooling problem. Fans are good both on the exterior and underneath the crawl space. The exterior is a Goodman CM36-1eb central air unit. The second part is the upflow furnace in the crawl space which is a model No.
GMP 0753REVB. The air runs and get cold, but then it freezes up. You can about a 1/2" of ice on the exterior freon line. It's wet where the upflow furnace is and the fan and coil is. Can't get to the coil because it is sheet metal enclosed. But will attempt to cut open the sheet metal tomorrow to see if it is dirty. The air flow is good in all rooms, and the fans are working good.
Any ideas anybody?
rebuildergirl is offline   Reply With Quote
Old 06-08-2009, 09:38 PM   #2
Your refrigerant charge is probably inadequate. You will have to have it checked preferably by a pro.
SKIP4661 is offline   Reply With Quote
Old 06-08-2009, 09:41 PM   #3
Central air unit freezes, fans okay, leaking freon
Had a tech come out who said the fans are good, and he input two pounds of freon. After it still was freezing.
Old 06-08-2009, 09:42 PM   #4
Central air unit freezes, air flow is good, fans good, freon added it still froze
The temperature was at about 40 degrees, but then dropped in about 15 minutes to 28. The tech said there was some type of blockage in the system.
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 11:23 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 06:10 PM
Used Central Air Unit? shep28 HVAC 2 04-21-2007 08:59 PM
central air unit question princessme HVAC 4 07-08-2006 10:13 PM
