Central Air Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 07-10-2010, 10:12 AM   #1
KBM
Central Air Problem
I have a Tappan FT3BA-048KA. I'm trying to find an Owner's Manual. Any ideas? The compressor periodically stops running and buzzes for about 2 seconds. This happens every three minutes or so and then the compressor will eventually run again. It cools fine once the compressor kicks in. The fan runs fine.
KBM is offline   Reply With Quote
Old 07-10-2010, 10:32 AM   #2
Compressor having a hard time starting can be a weak capacitor. Buy a new one and if it cures the problem great, if not you're out less then $20. Next step would be adding a hard start kit like the compressor saver brand.
The Following User Says Thank You to Marty S. For This Useful Post:
KBM (07-10-2010)
septic problem??? jjrbus Plumbing 2 09-09-2009 09:59 PM
Weed problem, bug problem, or both? hayzen Landscaping & Lawn Care 1 08-25-2009 06:33 PM
Central air quit cooling seems like only fan is running Rochelle HVAC 5 08-11-2009 09:24 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
