Central Air (outside Unit) Makes Strange Noise When It Turns Off. Am I In Trouble? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-12-2010, 03:21 AM   #1
Central air (outside unit) makes strange noise when it turns off. Am I in trouble?
Hi, I have a Carrier unit that I just recently noticed making a strange noise when it turns off. If you're near the outside unit when it turns off you'll hear a second or two of knocking (like someone sticking something in a fan blade to slow it down). I'm concerned about this as I know these units can be expensive. Our water heater seems to be on its way out as well, so we really don't need another even bigger problem. But I'd rather know than not know. Am I in real trouble here?
Player is offline   Reply With Quote
Old 07-12-2010, 06:26 AM   #2
An old Tradesmen
Rewards Points: 7,344
Without hearing the noise. Can't say if its serious or not.
Old 07-12-2010, 10:11 AM   #3
Rewards Points: 271
Do you know a good AC service company? Ask your neighbors if you know any of them, friends or co-workers. You might want to pay for a service call so a good tech can check it. The water heater may just need to be flushed and you may need a new heating element - they cost about $10.
Frank Lardino
FrankL is offline   Reply With Quote
Old 07-12-2010, 10:50 AM   #4
A distinguished gentleman from Canada on another thread on this very forum told me, for my compressor with the same symptom, that it was a broken motor support spring inside the compressor, with no cure [and an indefinite service lifetime remaining for the compressor].
But it could also be a worn fan bearing or a loose fan blade setscrew.
Old 07-12-2010, 12:32 PM   #5
Guess I'd better find someone to look at it. *fingers crossed*
Thanks!
Old 07-12-2010, 06:42 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
Distinguished, Hah, Cranky, Yah.
Old 07-12-2010, 07:49 PM   #7
Oooooook...
Brand new Coleman 97.5% furnace makes horrible whining noise junebuggy HVAC 10 11-15-2016 09:53 AM
Electric furnace makes loud noise like a breaker when it starts?? epyke HVAC 5 10-13-2009 05:03 PM
Taco IFC pump makes noise when it stops Addicted HVAC 21 04-14-2009 12:59 PM
Comfortmaker makes noise on start up JHIDS HVAC 2 03-03-2006 11:41 PM
