-   -   Central air evaporator and furnace placement question. (http://www.diychatroom.com/f17/central-air-evaporator-furnace-placement-question-103983/)
StretchinAZ 05-09-2011 02:15 PM
Does the evaporator for central air need to be placed directly above the furnace? I would like to have it mounted horizontally against the basement ceiling instead of vertically on top of the furnace.
Secondly, is there a specific amount of distance that a gas furnace needs to be from a breaker box? Where I would like to relocate the furnace would put it about 2 or 3 feet from the breaker box.
Marty S. 05-09-2011 02:24 PM
There are horizontal evap coils so yes you can. I believe the breaker box must have 3' of clearance
yuri 05-09-2011 03:06 PM
Why do you want a horz coil? You can get a horz coil but they are a lot more expensive and extra tin work and cost is involved. Local elec code dictates the panel distance along with the national code. Local code supersedes it. Make sure you get a proper ruling on it as the ins co may be concerned also.
StretchinAZ 05-09-2011 07:08 PM
I have a very old coal burning furnace that was converted to oil that I'm replacing. The old furnace is roughly 6 feet by 3 feet and right in the middle of basement. In the corner of my basement there is a concrete ledge that is roughly 3 feet tall. I want to put the furnace and ac there but the contractor said there wouldn't be enough room to have them stacked. So I wanted to get ideas before having him come back out. He said it would be best to keep the new furnace/ac in the middle. I was just trying to come up with ideas but it appears that that will be installed where the old one is now.
Does an interior clay tiled chimney require to be lined when converting to gas? There seems to be conflicting information on the web.
yuri 05-09-2011 07:43 PM
If you get a high efficiency furnace over 90% efficient it uses no chimney and plastic PVC vent pipes that go out the side wall and you can move the furnace around. still need the main ductwork. if the ductwork has more than one branch then 1 coil horz won't work as all the air needs to go thru it. where I am all chimneys like yours need a liner and possibly a smaller liner as it will freezeup in the old clay chimney. liner MUST match the size of the vent on the appliance/furnace and we usually use a double wall B-vent.
