#31 | |
central Air ConditioningQuote:
This is also why my best guess would be that you are draining condensate with the door off but not on. when the blower is pulling through the coil it would seem to be pulling a negative press on the drain and preventing it from draining. In ealier post others have mentioned condensate trap. I made a reference to it as well. I would start by checking what I wrote a few posts back. If you have already done that try to create a trap with the drain tubing I think you said you had. IIRC you said the drain is in vinal tubing. strap it in a way that creates a trap. If you don't know what is meant by a trap it would be where the tube would drop down at leat 2" and back up at least 1.5" and cause water to stay in the trap area. |
#32 |
Ok I got it I will check and try that thank you
#33 | |
Also, regarding posting pictures - click the "Go Advanced" button below the reply box, and the system will move you to the advanced reply screen. You can easily attach images from your machine then. |
| Display Modes | |
| central air conditioning | Gerrylynne | HVAC | 4 | 07-06-2012 07:31 PM |
| Sears central air conditioning systems | av-geek | HVAC | 9 | 05-02-2012 09:07 AM |
| moving central air conditioning unit | coopeli | HVAC | 10 | 10-05-2011 05:34 PM |
| Central Air Conditioning running all day | quaildog | HVAC | 26 | 03-14-2011 06:02 AM |
| Central Air Conditioning installation | Hrlyguy | HVAC | 1 | 08-02-2009 08:07 PM |
