Central Air Conditioning - HVAC - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 05:25 PM   #1
central air conditioning
i just had a new 3 ton air condition central air unit put in my house. it has been 2 hours and the thermostat still says 83 degrees. Has not gone down at all. how long does it take to cool down an 1800 sq ft house?
Gerrylynne is offline   Reply With Quote
Old 07-06-2012, 05:45 PM   #2
More than 2 hours. Should be cool by bed time though.
The Following User Says Thank You to Marty S. For This Useful Post:
Gerrylynne (07-06-2012)
Old 07-06-2012, 06:22 PM   #3
But I'd think your humidity level should drop pretty quick.
For my 2000 sq. ft house I think it goes down a degree per hour.
The Following User Says Thank You to Yoyizit For This Useful Post:
Old 07-06-2012, 06:26 PM   #4
Rewards Points: 6,652
I have a two ton that cools 1642 sq ft, and going from 72 to 70 at bedtime, depending on outside temps, I have seen it take aprox four hours to get the temp down.
All depends on inside temp, outside temp, time of the day and heat gain. Also has to not only cool the building, but also the furnishings. Also how much people are going in amd out, what electronics are on. Just too many variables to give you a straight forward answer.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 07-06-2012, 07:31 PM   #5
Rewards Points: 582
should take more than a few hours to remove humidity and cool...
Sears central air conditioning systems av-geek HVAC 9 05-02-2012 09:07 AM
moving central air conditioning unit coopeli HVAC 10 10-05-2011 05:34 PM
Central Air Conditioning running all day quaildog HVAC 26 03-14-2011 06:02 AM
Central Vac problem strongbow Electrical 4 10-23-2010 09:49 PM
Central Air Conditioning installation Hrlyguy HVAC 1 08-02-2009 08:07 PM
