Old 09-18-2005, 06:07 PM   #1
Central Air Conditioners with heat pumps
OK...
With natual gas getting so expensive, and with an air conditioner that is probably 25 years old, I'm considering replacing my existing unit with a unit that has heat pump capability also.
Considering I don't know what I don't know... what would you all advise? Are heat pumps to supplement gas forced air more expensive than AC alone? Reliable? Major tear up? Worth the trouble?
raycyrx is offline   Reply With Quote
Old 10-05-2005, 12:32 PM   #2
How you apply the product is directly related to your location. You can get 100% heat pump with electric back up heat, heat pump with gas change over. Your location, weather, and required equipment size will be the desiding factors.
rabadger is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Central heat and air unit leak ? bdalekid HVAC 1 03-21-2007 08:31 AM
get ready for heat pumps stubborn_ox HVAC 7 12-22-2006 09:42 AM
So Many Heat Pumps..... Help! MartyKF114 HVAC 2 05-10-2006 04:48 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 01:47 AM
