-   -   Central Air Conditioners with heat pumps (http://www.diychatroom.com/f17/central-air-conditioners-heat-pumps-1044/)
raycyrx 09-18-2005 06:07 PM
OK...
With natual gas getting so expensive, and with an air conditioner that is probably 25 years old, I'm considering replacing my existing unit with a unit that has heat pump capability also.
Considering I don't know what I don't know... what would you all advise? Are heat pumps to supplement gas forced air more expensive than AC alone? Reliable? Major tear up? Worth the trouble?
rabadger 10-05-2005 12:32 PM
How you apply the product is directly related to your location. You can get 100% heat pump with electric back up heat, heat pump with gas change over. Your location, weather, and required equipment size will be the desiding factors.
