Central Air Condenser Disconnect - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 10:10 PM   #16
An old Tradesmen
Rewards Points: 7,344
Originally Posted by hvaclover View Post
so are we done?
Baloney.
A fused disconnect is a security blanket. Does nothing in reality.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (04-22-2012)
Old 04-21-2012, 10:21 PM   #17
Originally Posted by beenthere View Post
Baloney.
Salomi!
Prove me wrong with facts instead of spinning numbers that every body knows but do not use.
I got documentation from Tecumseh, Copeland, Hupp (remember them?) and a dozen other REFER comp mfgr and thirty plus years of experience from Uncle to back me up..
And if the internal OL is so reliable, than why do they put heater OLs in motor contactors in larger tonnage equipment?
Make sure you Google this one too....
hvac5646 is offline   Reply With Quote
Old 04-21-2012, 10:36 PM   #18
Rewards Points: 616
Originally Posted by hvac5646 View Post
Salomi!
I got documentation from Tecumseh, Copeland, Hupp (remember them?) and a dozen other REFER comp mfgr and thirty plus years of experience.
fused diss connect does nothing....
carmon is offline   Reply With Quote
Old 04-21-2012, 10:58 PM   #19
An old Tradesmen
Salomi!
Then post all your documentation.
Old 04-22-2012, 08:09 AM   #20
...except protect the comp.
GET ONE THING STRAIGHT..THIS IS ABOUT FUSES VS BREAKERS (THEY DO NOT REACT AS FAST AS FUSES BECASE THEY ARE MECHanical) AND NON-FUSED DISCOs AND WHY A PROPER SIZED RATING IS IMPORTANT.
FURTHER, IT IS THE ABOUT WHY THE COMP OL NEEDS SUPPLEMENTAL EXTERIOR PROTECTION BECAUSE THE COMP THERMISTOR IS ONLY TEMPERATURE SENSITIVE AND NOT AMPERAGE SENSITIVE.
Old 04-22-2012, 08:40 AM   #21
Rewards Points: 582
wow we you guys are losing it ..way to much info....its just a disconnect.not surgery.....in my area over 30yrs of service...i have only seen maybe 10 disconnects with fuses...the rest pull outs.....you can let this die anytime now
Old 04-22-2012, 08:41 AM   #22
Rewards Points: 616
why the caps... easy... you cant always be right
Old 04-22-2012, 08:48 AM   #23
Rewards Points: 616
o.k. .... it was asked if you are required to have a fused disconnect.... the answer is no..... you can put one there if you like though....
The Following User Says Thank You to carmon For This Useful Post:
Old 04-22-2012, 08:50 AM   #24
because the thread was already drifting from the original topic.
And Been's confusing (which had nothing to do with "Fuses Vs Breakers" and why thermistors make inferior current OL protectors)post about NEC did nothing but blur the original idea that my post was getting across.
Old 04-22-2012, 08:54 AM   #25
Been likes to debate but he does not like to lose.
Much as I like the guy he purposely tries to confuse and spin the issue when a debate does not go his way.
Old 04-22-2012, 08:57 AM   #26
An old Tradesmen
No spinning here. And no claiming of manufacturer documentation, and then not posting such documentation.
Post your manufacturer documentation.
Old 04-22-2012, 09:14 AM   #27
No, ..YOU prove me wrong...This topic is in every HVAC text book from Doolins to Modern Refrigeration and Heating...So you should have no problem Googling the topic to disprove me.
You do spin answers ...Case in in point: the question I PMed you about FPM in a residential RA application that had a standard formula..remember what you PMed back?....and i was forewarned you would do that cause...well..YOU know why.
Prove me wrong if you can with you documentation....than I' will produce my documentation.
If I am wrong you should be able to do so thru published material that already exists on the web.
Right now I am done with topic 'till you post the doc to back you up.
Old 04-22-2012, 09:17 AM   #28
Rewards Points: 1,216
That has nothing to do with comp protection.
If a power supply is fused at both ends the one that blows depends on the impedance of the circuit. Does not matter which as long as one does, it's done what it was supposed to.
But I guarantee you that a dead short will NOT cause the internal thermistor to open. Since the operation of a thermistor is dependent on a resistance change to open the windings, it would not not react fast enough.
And, yeah, Been I know thermistors function on resistance change.
The thermistor OL was introduced to save money on an elctro-magnet or Klixon style inherent overload that is both amperage and heat sensitive.
Two types of overloads exist ..Thermal and thermal-current type. The second type is called an inherent OL because it senses amp draw and temperature.
Thermal type OL responds strictly to heat and provides POOR over amperage protection (as the comp gets hotter the winding slowly draw more amperage, slowly rising to thermal cut out).
Thermal-Current type OLs are designed to be current AND heat sensitive. They respond to heat and current changes and spike much more quickly than thermal protectors only.
The type thermistor we find in compressor is strictly heat responsive and not current sensitive. Short cycle a comp and it will draw locked rotor (assuming no start cap and potential relay) for several seconds before tripping on the internal OL.
Precious seconds that the windings are cooking away.
If it were a current sensitive OL it would trip almost immediately. But it is not.
They Comp mfgs throw the OL protection on the contractor. We have to provide properly sized fuses to protect BOTH comp and and conductors.
Thermal OL thermistors are just another way to save money on the manufacturing process.
" You mentioned dead short in your explanation, usually if it's a dead short it's dead weather you have a fuse or breaker, time to replace the componet that shorted." Nothing could have saved it.
COLDIRON is offline   Reply With Quote
Old 04-22-2012, 09:18 AM   #29
An old Tradesmen
I'm not posting any documents, since I didn't claim to have documents. Nor do I have to prove you wrong.
The thread will be much quieter now since your not going to post in it anymore.
Old 04-22-2012, 09:20 AM   #30
" I second that and agree with you 100%. And the last word forget about it."
Central Air Condenser Disconnect Skelleyman Electrical 15 04-21-2012 11:15 AM
Installing central air question about conduit from disconnect to panel angelas111 Electrical 2 05-27-2011 07:37 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
wiring my condenser fan to my central air unit 45lonnie Electrical 1 09-05-2010 09:52 AM
Moving condenser electrical disconnect, required? Dave Carney HVAC 7 07-27-2009 10:34 PM
