Central Air Circulation Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2009, 08:19 AM   #1
I have a bryant central air system. The unit outside turns on with no problem but when it is ready to turn on the circulation fan in the furnace, the fan kicks on for a second and then off. This happens three or four times and finally stays on. I replaced the circuit board in the furnace last year because the relay that turns the fan on was stuck on. I haven't had any problems with that since then. I have cleaned the outside unit completely (Coils, fan, etc.)
Eric Krueger is offline   Reply With Quote
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 10:01 AM
adding central air poger67 HVAC 3 04-28-2009 10:58 AM
Central vac, freezer, and gas water heater on same circuit? curls00 Electrical 7 03-10-2008 10:57 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 01:47 AM
