Central Air Burning Smell Intermittent - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 01:28 PM   #1
Central air burning smell intermittent
I have a 7 year old Lennox heating a/c unit which last night had a burning smell showed up only in the basement (where it sits) while it was cooling the house (very muggy and hot here in the Northeast), the smell I could not distinguish between burning rubber or possibly electrical motor burn. I immediately shut down the system, today I wanted to try to get a better understanding of what was making the smell so turned only the fan on but no burning smell. I then tried the A/C and again no burning smell? I tried each for a good half hour but the system worked as it should, cooling the house and pushing air. The heating system was cleaned and serviced last year but not the A/C, new filter about 2 months ago and no changes to the system have occurred.
Now the only available time for a tech to come out is not for two days, so my main question is would you run the system at all as long as there was no smell? Or would you leave it off till the tech services it? I'd like to get the humidity out of the house.
boku is offline   Reply With Quote
Old 07-14-2010, 04:21 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,144
Usually if a motor goes kaput then it spreads the smell thru the house and you don't just smell it in the basement. Had a service call where the guys washing machine motor overheated and smelled and he thought it was the furnace. Any other appliances down there that can be overheating?
Old 07-14-2010, 06:13 PM   #3
Just the water heater and the furnace, and doing the smell test determined it had to be the furnace. That and the basement was finished a couple months ago - researching sheetrock dust in the furnace is scaring the crap out of me.. tech doesn't come till friday
Old 07-14-2010, 06:40 PM   #4
What's the model number of the furnace?
Old 07-14-2010, 08:07 PM   #5
It's a Lennox elite series G26
Old 07-14-2010, 08:53 PM   #6
Go ahead and run it. No repairing that motor or control board so use it till it dies. Hopefully it will last untill Friday.
Old 07-14-2010, 09:02 PM   #7
Hvac Pro
yuri's Avatar
I wonder if the ventor fan got energized. They can stink real bad when seized up. Had one get backfilled with water from an improperly drained AC where it common joined to the furnace drain. The coil being higher will backfeed water if the drain hose gets plugged. Burns out the ventor when it is full of water.
Carefully watch for ice buildup on the big line. If so then shut it down ASAP as it is freezing up from a slow fan.
Old 07-14-2010, 10:23 PM   #8
thanks guys, will run it while I am able to keep an eye on it, the smiles on my daughters face as I switched it on where priceless.
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 09:08 AM
burning smell paulhomeowner HVAC 0 12-09-2009 10:33 AM
Bad smell from central air unit sodusme HVAC 19 09-13-2009 03:14 PM
Lennox 10acb24 - 11P Burning Smell pchangela HVAC 3 08-17-2009 09:42 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 09:29 AM
