Old 06-17-2007, 08:57 AM   #1
joe beer
central air from above
i have an older home with hydronic heat and i would like to have my a/c no longer in my windows. i've seen some ideas in granger and jonstone but i wonder if a unit in my attic may be too noisy. and hot. i also cannot find out where the filter would go id prefer never to go into the attic again after i'm done up there..
joe beer is offline   Reply With Quote
Old 06-17-2007, 08:08 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Some have a cover underneath for the filter, with the Air return being in that place.
Old 06-17-2007, 10:34 PM   #3
Union HVAC Tech.
You can put the filter at ceiling level with a filter grille (a hinged grille that allows filter access). Having an airhandler in the attic is very common. It should be hung from the roof framing on an antivibration mount to control noise.
bigMikeB is offline   Reply With Quote
re-routing central vacuum pipe yummy mummy Building & Construction 2 12-03-2006 05:30 PM
Need to remove old central air unit pmb003 HVAC 4 05-03-2006 05:05 PM
central ac, shooting water bobo Plumbing 1 07-15-2005 03:31 AM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 01:47 AM
