Old 07-13-2012, 05:38 PM   #1
Central air
My ac has been checked twice, the set temp is 70 when it reaches that is shuts off for 2 mins and kickes back on, at times it jumps to 72. It has been running 2 days straight, i have blocked the registers to force air up, cleaned my filter etc. It is blowing cold air but not strongly. My home is cold but the ac will not shut down.
Tanya1973 is offline   Reply With Quote
Old 07-13-2012, 06:56 PM   #2
JJboy's Avatar
Central air
Maybe you have the fan always in ON instead AUTO
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-13-2012, 07:15 PM   #3
An old Tradesmen
Central air
How hot is it outside.
Old 07-14-2012, 12:16 AM   #4
Central air
your house is cold...what is the problem......
carmon is offline   Reply With Quote
Central Air Conditioning running all day quaildog HVAC 26 03-14-2011 06:02 AM
Closed off room where central return is located markorious HVAC 1 02-17-2011 02:47 AM
Central Vac problem strongbow Electrical 4 10-23-2010 09:49 PM
Central vac, freezer, and gas water heater on same circuit? curls00 Electrical 7 03-10-2008 10:57 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 01:47 AM
