Central Ac Unit Keep Causing My Electric Braker To Kick Off - HVAC - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 08:05 AM   #1
Why Does My Central Ac Unit Keep Causing My Electric Braker To Kick Off . We have a Rudd central ac unit and it is extremely hot here now. The fan will keep blowing, but the outside unit will shut off, due to the circut braker tripping. We can flip the braker and the outside until fan and compresser will kick on. Run for a while and then kick off.
pamelah1105 is offline   Reply With Quote
Old 06-18-2012, 11:58 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Overamping, getting too hot, weak compressor, low on refrigerant. Slightly possible the breaker is too small but if it's been working for a long time prior than most likely not. Could also be that the breaker is weak.
Usually when the breakers start to trip the compressor is on it's last leg. Having said that when it's completely gone the breaker usually will not hold for even one split second on condenser start up.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
ben's plumbing (06-18-2012)
Tempstar Central Air Outdoor Unit LOUD psilva8 HVAC 4 05-24-2012 12:16 AM
Moving and improving a central AC unit NHoepner HVAC 14 07-19-2011 01:17 AM
central air unit question princessme HVAC 4 07-08-2006 09:13 PM
Removing Refridgerant from Central Unit wackerjr HVAC 1 06-23-2006 02:09 AM
Need to remove old central air unit pmb003 HVAC 4 05-03-2006 04:05 PM
