Central AC Return - HVAC - DIY Chatroom Home Improvement Forum
Old 05-18-2010, 10:18 AM   #1
Central AC Return
We have a small 2 story house (1550s.f.). The air handler/heating unit is located in the garage mounted on a enclosed box. The filter is located on the bottom of the air handler and the return grill is mounted on the wall in the family room. The return runs under a staircase through the wall to the box. The garage side of this void is not insulated and as best as I can tell the staircase void does not appear to be sealed (conditioned space) My question/problem.
#1 I want to fabricate a insulated pathway/duct from the return grill to the air handler to improve the systems efficency (conditioned to unconditioned space).
#2 And add a return duct from the second story ceiling back to the pathway/duct.
Do I have to reduce the existing returns size in direct proportaion to the new returns size? And can the new return duct be connected to the existing (improved/insulated) return anywhere to create the vacumun effect required?
I'm pretty handy but I don't spell to well .
Any and all input is appreciated.
jwwilliams is offline   Reply With Quote
Old 05-18-2010, 12:54 PM   #2
An old Tradesmen
Rewards Points: 7,328
Weather you need to reduce or not, depends on how big the duct to the second floor is. And how big it is to the current grille.
A drawing of what you have now. And what you want to do would help.
Old 05-18-2010, 08:59 PM   #3
Thanks Beenthere, I'll draw it up as best I can.
Old 05-25-2010, 07:23 PM   #4
Attached is a before and after drawing. The AC is a 3.5 ton unit, the air return grill's outside dimensions (31.5 x 11.5), proposed upstairs duct run I hope will be 8", the built up main return duct will be made out of insulated foam board rated at R6 minimum.
Any and all help is appreciated.
Old 05-25-2010, 07:29 PM   #5
An old Tradesmen
If your current return is slightly restricted/undersized. Then you don't need to make a reduction in the trunk anywhere.
If its not, just put a small restrictor plate just after where you attach your new return duct to. It will cause air to be pulled from the second floor return.
Old 05-25-2010, 10:49 PM   #6
Sorry, do you mean restrict the opening at the existing (main) air inlet (if over sized) to cause air to be sucked from the add on duct run?
Old 05-26-2010, 04:48 AM   #7
An old Tradesmen
If the area where your going to tap the new return duct into. Won't be easily accessible later. You can restrict it at the grille.
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 08:23 AM
return air honola HVAC 11 08-13-2009 07:41 AM
Enough Return Air? mjbxx HVAC 3 02-12-2009 06:26 PM
Central Air Installation Question ??? WorkOnIt HVAC 3 03-07-2008 04:04 PM
Central Air return duct location backpacker2 HVAC 3 05-28-2007 10:07 AM
