Central Ac Not Working Like It Used To - HVAC - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 07:43 PM   #1
central ac not working like it used to
ok so i just got this houe and the a/c has been working fine untill 3 days ago
there was a clogged pan line and i cleared that and the ac started working again
but 3 days later ?(today) i get the same error code saying i need to replace the air filter or clean it
i take off the access pannel and there's some water in it but not much
then the outside unit kicked on again and started working for no reason i didnt really do anything
then i noticed those copper tubes that are on the a frame in a shape of a u some of them were getting frost on them not much just coating it in white
the jerk who installed the thing really made it hard to take the whole pannel off and i can only see a small portion of it
im thinking i have to cut the pannel around a few screws to get it out since the screws will just not come out
i put the pannel back on and then i noticed that im not really getting much air flow outa my vents upstairs or on the main floor only the ones in the basement
i really dont have the money to be hiring someone at this moment to be coming to fix this
in a few mths i will but then i dont need the cooling
is there a way that i can check the coolant to see if theres enough
and is there anything else you guys can suggest?
diyer1 is offline   Reply With Quote
Old 07-12-2009, 08:10 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
You have one of two problems or both
1. Dirty filter
2. Low on freon
Check filter first if not dirty call a tech to service the a/c and turn it off until it is serviced. If it freezes up you can cause compressor damage.
Old 07-12-2009, 08:36 PM   #3
dirty air filter or the filter where the condenser is
the filter isnt dirty i just replaced it
Old 07-12-2009, 08:42 PM   #4
Rewards Points: 560
Then you are probably low on charge. If you are seeing frost then the line temp is below 32 deg and freezing.
Unless you have a gauge set to check the pressures and a manometer to check line temp you will need to get a pro to add freon.
Yes the filter at the furnace.
Old 07-12-2009, 09:03 PM   #5
well if im low on freon does that mean i have a leak?
also im getting ALOT less airflow outa my vents with just the fan on
Old 07-12-2009, 09:07 PM   #6
Rewards Points: 560
Yes you could have a small leak.
But with weak air flow you may have a coil that isplugged with lint and dirt that could cause a restriction as well.
Old 07-12-2009, 09:32 PM   #7
so i would be able to clean that myself right
just open the big pannel take off teh cover to the a frame and clean with that foam and a brush?
Old 07-13-2009, 12:53 AM   #8
ok so would the evaporator be the one i need to clean or would it be the condenser unit outside?
which one is dirty is the air flow is restricted even with the ac unit off just the furnace on high fan
Old 07-13-2009, 06:46 AM   #9
HVAC / Plumbing
Evap. coil
kenmac is offline   Reply With Quote
Old 07-14-2009, 06:59 PM   #10
ok cleaned it with 2 cans of foam hopefully that was enough
will see in a little bit
was i sposed to take off the side of the aframe and spray in there too?
also is there anything else that would make my vents have less flow?
Old 07-14-2009, 07:41 PM   #11
Rewards Points: 560
Do you still have ice or frost?
Old 07-14-2009, 11:41 PM   #12
well the thing is i dunno cant see without it being open
and if its open there isnt enough airflow correct?
ill open it tomorow after its been runing a while
its dropped the house 6 deg since about 5 pm
b4 it would just get an error code and do nothing
i think i may have been geting frost from it being open too when i first opened it there wasnt any frost
only after it had been open a while it got frosty ps there was never any ice only frost
Old 07-15-2009, 02:30 AM   #13
ok so im pretty sure now that blower isnt working like it used to it seemd the blower was alot louder b4 and i think pushing out more air
b4 all my problems the whole furnace was very noisy only a few days b4 tho
so im wondering if the fan working harder has fired it somehow and now only runs at a medium speed
my ducts are now sweating too
Help please, Central Air not working properly ned4spd8874 HVAC 8 06-21-2009 11:32 AM
Central A/C stops working same time every day mckwvu HVAC 11 06-16-2009 10:11 PM
Central Air Unit is freezing up, all fans working rebuildergirl HVAC 3 06-08-2009 08:42 PM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
Central Air Installation Question ??? WorkOnIt HVAC 3 03-07-2008 04:04 PM
