Central AC Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 04-20-2011, 11:18 PM   #1
Central AC not working
My ac is not blowing cold air. Upon inspection, the outside compressor does not come on when I turn the ac on unless I press the compressor contactor. I have a question about wiring.
I have a control box mounted to the heater in the attic where all the connections are made. From the thermostat R G W are tied to R G W on the control box. Y and R from the gas valve are tied to B/C and X on the control box. From the contactor at the outdoor mounted condensor (split system), the red wire R is wirenutted to the yellow wire Y from the thermostat.
The white wire W from the condensor contactor is not attached to anything. The compressor contactor will not catch. I suspect because the white wire is not connected, it does not complete the circuit and therefore does not power the solonoid to hold the compressor contactor.
The name listed on the control box is "Central Environmental Systems" which I have found out is no longer in business. I am not an ac tech, but I do have an electrical background. However, I am unable to obtain schematics.
What should the white wire from the compressor contactor be tied to?
dyinginlasvegas is offline   Reply With Quote
Old 04-20-2011, 11:30 PM   #2
JJboy's Avatar
It can be the condenser is not receiving the 24v or the contactor solenoid is open. AC was working so I think you should focus in your condenser first.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 04-21-2011, 12:29 AM   #3
I'm Your Huckleberry
Rewards Points: 2,270
common, b/c.
Doc Holliday is offline   Reply With Quote
Old 04-21-2011, 05:44 AM   #4
Rewards Points: 1,216
Check for 24 volts at the control side of the contactor first.
COLDIRON is offline   Reply With Quote
central vac stopped working wendl Appliances 2 07-04-2010 08:06 PM
central ac not working like it used to diyer1 HVAC 12 07-15-2009 02:30 AM
Help please, Central Air not working properly ned4spd8874 HVAC 8 06-21-2009 11:32 AM
Central A/C stops working same time every day mckwvu HVAC 11 06-16-2009 10:11 PM
Central Air Unit is freezing up, all fans working rebuildergirl HVAC 3 06-08-2009 08:42 PM
