Central AC - Line Set Question - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2013, 09:53 AM   #1
Central AC - line set question
I have a 4 year old residential central ac system-with coolant leak problems-recently repaired.
My question-line set- small diameter copper pipe- should this pipe be hot to the touch (can't keep fingers on it) at condenser or should it be just warm when running? The reason I ask is that I have central AC at work (vintage 1970) and one pipe is VERY hot.
Are newer residential units different or do I still have a problem with repaired system? THANKS
wmmurphy is offline   Reply With Quote
Old 07-01-2013, 11:02 AM   #2
No it should be warm to the touch, try cleaning the coil first.
Sent from my iPhone using DIY Forum
ryandeen is offline   Reply With Quote
Question on return line for water heater daluu Plumbing 10 09-09-2012 10:38 PM
two part central A/C question fred54 HVAC 5 03-22-2012 07:57 PM
Weird question about Central AC and basement WompaStompa HVAC 5 07-10-2011 10:17 AM
A/C zip line question JeffL Electrical 2 06-09-2011 06:52 PM
Central heating/air question :-) florida HVAC 4 12-06-2010 03:59 PM
