Central AC Issue: Goodman CK30-1B - HVAC - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 08:43 PM   #1
I have a 10-15 yr old Goodman unit in a rental home. Last summer, the condenser fan stopped running. The dual run cap was bulged so I replaced it. A few weeks later, the condenser fan stopped running again. So, I replaced the fan. It worked for a good three months (end of summer '08 and including end of spring '09). Last week it quit again and I found the cap was bulged. So I replaced it just to get it running again but I'm sure there is more of a deep rooted issue here.
I'd like to get an HVAC service person out there to do a full inspection, but was hoping to get advice from members of this forum on what I should expect them to find - given the prior sequence of events. What should I make sure they check specifically?
Would a hard start kit help in this situation? Is installing a hard start kit a DYI type project?
Thanks in advance...
jsabe is offline   Reply With Quote
Old 05-25-2009, 08:49 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,852
Capacitors these days are CHEAP and you may have just got unlucky and had another bad one or a power surge. A hard start kit is only for the compressor. Make sure you take a garden hose (no pressure washer) and flush the outdoor coil thoroughly. Lack of air flow will overheat the motor and could fail a capacitor. Make sure they check the freon level and the contactor for burnt and pitted contacts which can cause a low voltage issue.
Old 05-25-2009, 08:54 PM   #3
Thanks for the quick reply.
Speaking of air flow, the people that lived in the house before me put a shed about 2 ft away from the condenser unit and on the other side of it is the house. Do you think I should take that shed down?
Old 05-26-2009, 07:27 PM   #4
Hvac Pro
yuri's Avatar
Probably not. Post a pic of it here so we can see it.
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Goodman central a/c and heat petroman HVAC 1 04-18-2008 08:36 PM
Goodman & Roll out switch issue? wsquared HVAC 1 11-10-2007 11:12 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
