Central AC - Full Installation - HVAC - DIY Chatroom Home Improvement Forum
Old 06-09-2008, 11:41 AM   #1
I have a cape cod house that does not have duct work. The first floor is about 1000 sq. feet, the second floor is around 850. There is also a full unfinished basement.
I am planning to install conventional central air in the house. The second floor is undergoing renovation. There is no sheet rock and new insulation is yet to be installed. I am trying to figure out if
1) 1 unit can handle two floors or do I need two sets of everything installed?
2) Where should duct work and air handler be installed ? (attic and run down to the first floor, basement and run up to the second floor, or both).
alex333 is offline   Reply With Quote
Old 06-09-2008, 03:07 PM   #2
Typically for every 1000Sqft you need 1 ton of cooling for a general rule if you don't want to calculate your heating and cooling loads in regards to your windows/doors/insulation ect.
mfleming is offline   Reply With Quote
Old 06-14-2008, 06:01 PM   #3
Rewards Points: 150
wrong
if you dont want to do heat load calc us 1square foot for every cfm and 400cfm per ton
geo fan is offline   Reply With Quote
Central Air Installation Question ??? WorkOnIt HVAC 3 03-07-2008 04:04 PM
Full Clutchcargo Off Topic 0 05-24-2007 08:46 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 12:47 AM
