Cental Air Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 05:28 PM   #1
Cental air problems
When i flick my thermostat to cool everything comes on runs for a couple min them my blower shuts off before reaching temp then turns back on and it keeps doing that the central air unit stays on just the blower shuts off Any help woukd be nice thanks
Cuzzi is offline   Reply With Quote
Old 07-20-2011, 06:17 PM   #2
i'm no expert but there may be a problem with the blower motor. also might want to check the filter or if the fan on the blower needs cleaning.
hollylzahn is offline   Reply With Quote
Old 07-20-2011, 06:25 PM   #3
Filters clean when i flick the fan to on it runs fine now i have had it running for about an hour and a half on auto and everything seems fine now so i dont know whats up with it
Old 07-20-2011, 07:29 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
circuit board cooling fan relay may be failing.
Old 07-20-2011, 09:00 PM   #5
I just got the mother board replased 8 months ago could my thermostat be blown
Old 07-20-2011, 09:25 PM   #6
Hvac Pro
yuri's Avatar
Yes. The tstat energizes the G terminal on some boards/units to turn on the fan with the cooling. others do it thru the Y terminal on the board. if the switch in the subbase for ON to Auto is loose/bad or making an intermittent connection then that is your problem. That is why I ALWAYS recommend the higher quality Honeywell or other better brand name tstats rather than the el cheapo no name offshore pieces of junk. You get what you pay for. Honeywell Focus Pro from HDepot is a good choice.
Old 07-20-2011, 09:42 PM   #7
Thanks i will buy a new tstat and try it it seemes to be working fine now but i will replace anyway
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 09:44 PM
Multiple problems in 3 year old house I just purchased swenard Plumbing 12 08-31-2009 04:53 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 03:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
