Cementitious Coating Over PU Foam - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2008, 07:23 AM   #1
cementitious coating over PU foam
Hi all,
I've got some PU spray foam in my basement, and some of it is pretty awkward to cover with drywall. I'd like to cover it with a cementitious fire-rated coating, but the insulation company has a high minimum for this ($1 K). Does anyone know of a DIY option?
Thanks,
Paul N.
pauln is offline   Reply With Quote
Old 09-09-2008, 09:13 AM   #2
Whatamess
How about this http://www.selleys.com.au/Selleys-Fi...t/default.aspx
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 09-09-2008, 09:37 PM   #3
Originally Posted by TazinCR View Post
Interesting, thanks for the suggestion. PU foam isn't on the list of possible materials to put it on, however. Do you know if it's been used for this purpose?
Thanks,
Paul N.
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 08:18 AM
why use paint brushes instead of foam brushes? joeyboy Painting 18 09-23-2007 05:52 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
SPF Foam Roofing on Gables? WhyMeWhyNow Roofing/Siding 3 07-25-2005 05:31 PM
