Old 05-21-2010, 09:22 PM   #1
Cement crawl space ventilation
Hi -- new to the forum..
My 20'x30'x6' crawl space has cement floors, and stays very humid. Even with a large dehumidifier running the humidity is around 70%. The crawl area is where my furnace, hot water heater, and washer/dryer are located.
I ordered a 200 CFM powered crawl space vent which has a built-in thermostat and humidistat.. It will be installed on one side of the space and a standard non-powered vent on the other side.
My question for the forum is whether I should run a fan inside the crawl area to circulate the air, or just let the vent fan draw air from the standard vent?
sheslostcontrol is offline   Reply With Quote
Old 05-21-2010, 10:48 PM   #2
An old Tradesmen
Depending where your located at. The power venting could make the crawlspace worse. Since it already has fresh air coming into it.
Old 05-22-2010, 07:56 AM   #3
sorry -- I'm in Georgia.
The humidistat will turn the fan & standard vents off if the humidity rises above a set level (like during a rain storm).
As of today there is no air coming into the crawlspace. No ventilation whatsoever.
Old 05-22-2010, 08:02 AM   #4
An old Tradesmen
IS your water heater connected to a chimney? If it is, then air is being drawn into the crawl.
If it isn't, then the water heater is causing your humidity problem.
Old 05-22-2010, 08:18 AM   #5
It may be, but before the water heater was filled up & turned on I still measured 70% humidity. I'm currently at 70-75% with the water heater operational.
Old 05-22-2010, 08:23 AM   #6
An old Tradesmen
A chimney drafts/draws air up through it, weather or not the water heater is filled or not, and weather the burner is on or not.
Old 05-22-2010, 08:25 AM   #7
I do not have a chimney -- there is a flue for the furnace, but that is closed off to crawlspace air as best I can tell.
I was planning to place the powered vent near the top of the wall, to pull the most humid air.
Old 05-22-2010, 08:39 AM   #8
An old Tradesmen
Ok.
Where does the water heater vent to. Does it have a chimney. Or does it just vent into the crawlspace.
High humidity in a crawlspace, often comes from the crawlspace being vented.
Old 05-22-2010, 08:48 AM   #9
The house sat without power and water for several months. During this time, with no water in the heater (drained), and no ventilation, the humidity was around 80%. The previous owner had zero ventilation in this crawl space. I haven't added anything other than a dehumidifier (which feeds into a bucket I empty about once a day).
Old 05-22-2010, 09:32 AM   #10
An old Tradesmen
Sorry.
Since you don't answer my questions.
I'll leave someone else help you. Good luck.
Tags
crawl, fan, powered, space, ventilation
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
Crawl Space Ventilation with Wiring and Piping Passing Through scubber Building & Construction 1 02-09-2009 09:59 AM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 04:11 PM
thoughts on crawl space heating rtoni HVAC 3 09-30-2008 01:47 PM
Crawl Space needs "re-insulating" bigNY Building & Construction 1 10-12-2006 02:55 PM
