Old 08-15-2007, 03:46 PM   #1
Unhappy celiera 18000 btu won't heat
hi! just install my celiera 18000 btu and on the cooling mode it's work fine but on the heat mode there is an error code (E70) in the instruction manual it's say EXTERNAL FEEDBACK FAILURE Help please
tiquen is offline   Reply With Quote
Old 08-16-2007, 07:53 PM   #2
Union HVAC Tech.
Check the transducers, one must be disconnected or giving a false reading.
bigMikeB is offline   Reply With Quote
Old 07-18-2008, 12:22 PM   #3
Question celiera
I'm not sure what your problem is but I'm having a problem just hooking mine up. The little booklet to hook up could be more clear. Did you hook yours up yourself? I need a little help.
Joe
jogle is offline   Reply With Quote
Old 07-21-2008, 08:12 AM   #4
Yes i did hook up mine by my self quite easy, do you have the same model? be sure to connect all the cable and if you need the wiring diagram i can sent them to you. And for the piping connection a friend of mine came to vacuum the piping before opening the gas valve.
and i'm realy sastisfed with my unit
Old 07-21-2008, 11:04 AM   #5
Hi Tiquen. I have also just installed an 18000 BTu Celiera Split. It cools and heats very well, but I can't control the temperature. It will cool or heat to an undetermined temp no matter what the set point is. One problem is the lack of operating information that comes with it. I don't know what it should do and how to set it up.
Does anyone have more info on the operation of this unit?
roger104 is offline   Reply With Quote
Old 07-23-2008, 06:27 PM   #6
Default 18000
Hi again,
i have quite the same problem when it on automatic so i put on cool or on heat never tryed to solve the problem. By the way where did you baught it i got mine on e-bay
Old 07-24-2008, 11:23 AM   #7
Default Celiera 18000 BTU operation
I bought mine online at ac-world.com.
When you are operating in the cool mode, does the fan cycle on and off with the compressor, or is it always on? How about when it is in AUTO?
Old 07-25-2008, 12:43 PM   #8
Hi
Ok when on cool mode the never stop but the compressor does and on automatic the fan and the compressor stop i add the same problem but ther was a cable that wasn't blug but now it work good, the cable was the one that you pluk in the back of the interior unit (for the defrost) if you give me your e-mail a can send you the complete wiring conction but only in 2 week cause i'm leaving for some vacation
Old 08-03-2008, 02:56 PM   #9
Unhappy
Hi all,
I purchased the same unit, Celiera 18000 but don't know from which unit, internal or external, I need to connect to the main power? A wiring diagram would be best.
Thanks in advance!
Linh
trinhyulinh is offline   Reply With Quote
Old 11-03-2009, 12:49 PM   #10
tiquen,
Hi, can you send me the wiring diagram for the Celiera 18000 BTU mini-split air-conditioner? Thanks,
Steve
syates03 is offline   Reply With Quote
More On This Topic
Hi! My name is Kip Bradford and I am here on behalf of Expert Village. In this clip, we are going to talk about the signal flow. The microphone creates a voltage. It in induces a voltage which is an electrical representation of the sound that we gave it... Read More »
In this clip, we're going to talk about the proper way to diagnose and repair your rear defroster grid. In this step, we're going to talk about the proper service procedure for installing our rear defogger repair stencil. Alright. What I'm going to do is... Read More »
Learn how to clean a fender stratocaster electric guitar in this diy guitar tech video. Read More »
Learn how to read the warning signs on the tank of an air compressor in this free video. Read More »
Part 1 - Learn how to string a fender stratocaster electric guitar in this diy guitar setup video. Read More »
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 02:27 PM
Getting a House..heatpump or no? DavidsCPU HVAC 9 11-27-2006 08:08 AM
heat wont come on with t-stat in auto wahanks HVAC 1 11-22-2006 03:55 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 10:57 PM
heat pump not working kyleGR HVAC 2 05-30-2006 04:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
