-   -   celiera 18000 btu won't heat (http://www.diychatroom.com/f17/celiera-18000-btu-wont-heat-10753/)
tiquen 08-15-2007 01:46 PM
hi! just install my celiera 18000 btu and on the cooling mode it's work fine but on the heat mode there is an error code (E70) in the instruction manual it's say EXTERNAL FEEDBACK FAILURE Help please
bigMikeB 08-16-2007 05:53 PM
Check the transducers, one must be disconnected or giving a false reading.
jogle 07-18-2008 10:22 AM
celiera
I'm not sure what your problem is but I'm having a problem just hooking mine up. The little booklet to hook up could be more clear. Did you hook yours up yourself? I need a little help.
Joe
tiquen 07-21-2008 06:12 AM
Yes i did hook up mine by my self quite easy, do you have the same model? be sure to connect all the cable and if you need the wiring diagram i can sent them to you. And for the piping connection a friend of mine came to vacuum the piping before opening the gas valve.
and i'm realy sastisfed with my unit
roger104 07-21-2008 09:04 AM
Hi Tiquen. I have also just installed an 18000 BTu Celiera Split. It cools and heats very well, but I can't control the temperature. It will cool or heat to an undetermined temp no matter what the set point is. One problem is the lack of operating information that comes with it. I don't know what it should do and how to set it up.
Does anyone have more info on the operation of this unit?
tiquen 07-23-2008 04:27 PM
18000
Hi again,
i have quite the same problem when it on automatic so i put on cool or on heat never tryed to solve the problem. By the way where did you baught it i got mine on e-bay
roger104 07-24-2008 09:23 AM
Celiera 18000 BTU operation
I bought mine online at ac-world.com.
When you are operating in the cool mode, does the fan cycle on and off with the compressor, or is it always on? How about when it is in AUTO?
tiquen 07-25-2008 10:43 AM
Hi
Ok when on cool mode the never stop but the compressor does and on automatic the fan and the compressor stop i add the same problem but ther was a cable that wasn't blug but now it work good, the cable was the one that you pluk in the back of the interior unit (for the defrost) if you give me your e-mail a can send you the complete wiring conction but only in 2 week cause i'm leaving for some vacation
trinhyulinh 08-03-2008 12:56 PM
Hi all,
I purchased the same unit, Celiera 18000 but don't know from which unit, internal or external, I need to connect to the main power? A wiring diagram would be best.
Thanks in advance!
Linh
syates03 11-03-2009 10:49 AM
tiquen,
Hi, can you send me the wiring diagram for the Celiera 18000 BTU mini-split air-conditioner? Thanks,
Steve
