Ceiling Vent Settings - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2009, 06:12 PM   #1
Question
Ceiling Vent settings
I discovered a second set of flaps inside the ceiling vents - in some rooms they were closed and in others they were open. I opened all of them and since then the HVAC is not working right. It turns on and blows cool air for a few minutes then switches to just the fan blowing. It goes back and forth and the building temps keep climbing. Did opening those inner flaps have anything to do with this? Should they be opened or closed?
nvdayspa is offline   Reply With Quote
Old 09-06-2009, 06:37 PM   #2
JohnH1's Avatar
Nope. Opening the dampers in vents will nat cause the a/c to stop operating and only run the fan. You have something els going on now.
JohnH1 is offline   Reply With Quote
Old 09-06-2009, 06:38 PM   #3
JohnH1's Avatar
Unless the room the t-stat is in is over cooling and you are running on a constant fan setting.
Condensation from Ceiling AC Vent meth HVAC 29 12-15-2013 11:02 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
HVAC Ceiling vent falling off, how to fix? guile Building & Construction 4 01-20-2009 02:44 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Cathedral ceiling without sofit vent on one side ChrisO Roofing/Siding 3 01-31-2007 10:51 AM
